how do i know when a transmission is installed "correctly"?
Old Apr 14, 2003 | 11:06 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i was told that my front seal went out cuz of improper installation.........now how would i know it's properly installed when i put it back in after i get it fixed???
Old Apr 15, 2003 | 05:23 AM
ede's Avatar
ede
if the trans is on the dowels in the back of the block it's installed correctly. good bet for a replacement seal failing is installing it with the lips dry and it burning up on start up before oil can get to it.
Old Apr 15, 2003 | 11:42 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
ok so when replacing the seal one would have to put some fluid on the seal and then it will be okay.....right?
Old Apr 15, 2003 | 02:12 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
yes. dexron or vaseline.
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
formula_novice
Aug 18, 2015 08:48 PM
