speedo drive gear retaining clip from an 83 700r4 to a 92 700r4 ?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
does anyone know if i can use retaining clip from 83 700r4 output shaft speedo drive gear and use that all on a 92 700r4 output shaft in order to convert it away from VSS and to cable driven setup ???
thge 83 tranny has large style speedo body just like what i assume the 92 one has
thanks for anything
thanks for anything
Car: `86 SS / `87 SS
You can use the 83 speedo gear, speedo gear sleeve, and retaining clip / bolt in the 92 tailhousing, yes.
Engine: 4.3L Z TBI
how about the VSS setup and clip on the 83 output shaft ? thats actually what i meant ot find out about but i was asking backwards
thanks
thanks
Engine: 4.3L Z TBI
totally different type of gear though, judging from pics i have seen on the 700r4 page anyways
thanks
thanks
The VSS type speedo has a pressed on steal gear/reluctor on the output shaft.
The mechanical driven speedo gear is plastic and is retained to the shaft with a metal clip.
The late output shaft with the steel straight cut gear (pressed on) should still have hole provisions for the metal clip/plasic gear. The tail houseings should also interchange.
Okay you're missing the point here.
Unless a 1992 700-R4 is different from a 1991 700-R4, this should clarify.
The 1991 700-R4 I have is out of a 5.7L red Z28. It's matching numbers to the car. It had a normal plastic speedometer drive gear on the output shaft. The VSS is driven off that, and has a plastic gear on itself inside the tailhousing.
ALL I HAD TO DO TO CONVERT IT WAS USE A SPEEDO SLEEVE AND DRIVEN GEAR. The 1991 A4 does NOT have a metal reluctor ring. If 1992 does, I'm sorry.
The metal reluctor ring style didn't start until 4th gen years, 1993 maybe, 1994 for sure.
Hope that makes sense.
beachrodder
Aug 7, 2015 04:27 PM
