broken axle or broken side gear?
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
Hey there, I was leaving school today and everytime I turn the car while driving I hear a really bad thud (almost like something hitting the underbody of the car). I looked under it and didn't see anything busted or that would dramatically interfere. I jacked it up and the axle isn't totally busted, but something in the rear is really damaged. I replaced the rear gears with 3.73's about a year ago and put in a POSI unit. The posi was freshly rebuilt and wheel bearing and seals were replaced.
What are the odds that either the axle splines are damaged or that its a cracked side gear? Which is more likely? Is there a way that I can check this without taking the diff cover off?
Thanks in advance,
Mike
Thanks in advance,
Mike
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
