Highspeed Gear Question
Car: Camaro IROC-Z Convertible & Camaro
Transmission: Auto & 6 SPEED
Axle/Gears: 2.73 & 3.42
I need a 150+ mph potential but I also want some more power through the gears. I drive a lot of Autobahn here in europe at speeds at least 90-100mph. Which gears would work best for me? Will 3.08's make that much of a difference ? I currently have a 2.73 posi rear end.... would it be possible to just swap the ring and pinion out of a used 3.08 rear since I want to keep my axle ? would it be a lot of hassle ?
Alex
Alex
Car: `86 SS / `87 SS
so you're going to change from 1.911 final drive ratio (0.70 OD * 2.73) to 2.156 final drive ratio (0.70 OD * 3.08)
70mph is usually close to final drive * 1000. So with 3.08 gears 70mph rpm = 2156rpm, so 140mph would be around 4300?
If you are looking for more power at higher rpms, I would change intake manifold and go with headers. I would do this way before I could make a minimal gear change from 2.73 to 3.08.
Matthew
Matthew
Matthew,
Thanks for explaining me... I'm about to change the intake and runners anyway, just thought 3.08 gears may increase my acceleration a little more. Is there a way of telling what kind of gain I could expect from just that small gear change ?
well,
2.73 = ~3822rpm @ 140mph
3.08 = ~4312rpm @ 140mph
I don't know how much hp you make at those rpms. Have you dynoed the car?
I think if I was in Germany, I would go for a mini-ram
but not on a 305; I'd go 350 as well....
but not on a 305; I'd go 350 as well.... Thread Starter
Thanks... well I haven't dynoed my car yet, I plan on doing that after everything is finished.
A mini-ram setup on a 350 would definitly kick butt overhere with so many fast cars everywhere ... but I don't even want to think about the cost over here
..... I was lucky to find a lingenfelter street ram setup that I'm about the put on in addition to a cam and some other small things....
junkcltr
Aug 2, 2019 11:12 PM
