pulling and replacing 700r4, HELP!
Old Apr 30, 2003 | 01:49 PM
awdcamaro's Avatar
Ok, I have a big problem on my hands guys. I dropped my tranny and I'm not sure what to do. Everyone is telling me that I need to have a professionally rebuilt one put in by a professional, but I want to do it myself. Is it even economical to bother with an auto or should I just put a t56 in? I have no idea what I'm doing, but I'd love for anyone and everyone to offer ideas and prices of what I can do. I'm already hurting over the fact that it happened, but also that the car is no longer for sale (unless somebody wants a stock L98 z w/ a busted up tranny), so I can't start building my LS1 awd iroc. Please help me. Thanks.
Old Apr 30, 2003 | 04:41 PM
91Z28-350's Avatar
Take that tranny, go to a tranny shop and have it rebuilt. You can then install it yourself, since you removed it. If you want the T-56 think long and hard about it, and research the hell out of it to find out what it entails. It'll cost more than having the tranny rebuilt by a reputable local shop. For guestimates, the T-56 setup will run you double what it'll cost to rebuild the 700R4. There's lots of little things to get, and do with a T-56 swap.
Old Apr 30, 2003 | 04:49 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I'm in the process of replacing my 700R4 right now. I have it removed and am currently waiting delivery of my Pro-Built. I did some research and around here it cost as much to rebuild to back to stock as the Street/Strip 700R4 from Pro-Built cost me. If you have already removed the tranny then you have done the hard work. Just get a Pro-built and install it yourself.
Old Apr 30, 2003 | 08:03 PM
awdcamaro's Avatar
What's the best way to pull it? And where would I get a Pro-built? Are there any good sites?
Old May 1, 2003 | 04:15 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
The only place I know to get them is to order it directly from Dana at www.Pro-built.net. He pretty much builds them to suit your needs. The best way to remove it is one bolt at a time. Remove the torque arm, dipstick tube, oil lines and cables. Then lower remove the 6 bolts that attach the tranny to the motor. A transmission jack would be helpful but not required.
Old May 1, 2003 | 08:40 PM
awdcamaro's Avatar
thanks, a friend of mine and i are going to do it as soon as i get the $ for the new one
formula_novice
Aug 18, 2015 08:48 PM
mizz0313
Aug 12, 2015 06:45 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
drathaar907
Aug 6, 2015 04:20 PM
Leggman1
Aug 6, 2015 04:15 AM
