Roller Pilot Bearing or Brass Pilot Bushing??
Old Apr 30, 2003 | 08:46 PM
HyperSpeed's Avatar
Just wondering what would be more worthwhile to get. I asked the tech guy at Summit to send me the best "pilot bearing" they have. He recommened the RamClutches pilot bearing which turned out to be a brass bushing when it got to my door. I'm not sure whether to use it or return it for a true roller bearing.
I guess if I use my common sense, the roller bearing would be better as there is less friction on the pilot shaft. But after giving it some more thought, installation is also a bit more tricky as I would need to make sure the bearing isn't damaged as the transmission is going in. Decisions desicsions.
What do you guys think?
Old Apr 30, 2003 | 10:16 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i used a roller bearing, its not harder to put in, and it's designed to 'guide' the input shaft in not damage it
Old May 1, 2003 | 12:23 AM
Steves91z's Avatar
Use the brass pilot. I had a roller one in my car once. Somehow it went dry. Sounded like a spun bearing. A hell of a lot of work to find the problem and replace the part.
Steve
Old May 1, 2003 | 05:33 AM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
i agree with steve,ive used both ,i used them in all my circle track motors i built,so to gain any less friction we could,but on the street it wore out fast got dry and wiped it out for now on i use a bushing on the street motors.
Old May 1, 2003 | 09:17 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I prefer the bearing. It is the stock arrangement in most cars these days. Properly installed, there's no problem with them "running dry".
But either one will work fine.
If you really want a bearing, get one either from GM, or the Moroso one. They're about the same price, in the $12-15 range.
Attached Thumbnails Roller Pilot Bearing or Brass Pilot Bushing??-pilot-bearing.jpg
Old May 1, 2003 | 12:28 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I had vibration issues, and after replacing everything else, I finally put a bushing back in and my vibration seems to be gone now. Although mine wasn't in long enough to cause problems, when a pilot bearing goes bad, it ruins your input shaft, and can also ruin your flywheel, clutch and pressure plate. Not worth it to me... there just isn't enough of a benefit by having one.
Some guys that run real high rpms also seem to prefer the bushing. Apparently the bearings don't take too kindly to high rpms... which is probably why the only stock application for the bearing that I could find was for diesel pickups.
Old May 1, 2003 | 03:40 PM
HyperSpeed's Avatar
I think I'll stick with the brass bushing. It might save me a headache later on. Thanks for all the replies.
Old May 8, 2003 | 12:51 AM
HyperSpeed's Avatar
Since I forgot to ask earlier...
I am going to be installing the brass bushing this weekend. Do I need to lube the bushing where the input shaft is inserted or just leave it dry? I don't know anything about brass bushings.
Old May 8, 2003 | 01:40 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
I'm running a bearing in my car. I've put about 10k miles on it since and it still runs great. When you install it you have to pack it with grease well (like all bearings) and you won't have a problem. For the bushing make sure to put some grease in there too. You don't want metal to metal contact as that will wear out the bushing and the input shaft.
Old May 8, 2003 | 08:04 PM
Steves91z's Avatar
When you install a brass bushing it is not necessary to lube it. The material used is called oilite which is simply an oil impregnated brass. The most important thing you can do is to make certain that you have a very snug fit. When I do it, I place the bearing into the freezer over night. The cold will cause the bushing to shrink a very small amount. I measured this once at around 3 to 4 thousands. Have the crankshaft exposed on the back of the motor so the bushing does not get a chance to warm back up. Take it out of the freezer and tap it into the back of the crank. Ideally, it will go in with a little resistance. As it warms it will expand and not come out willingly. If it makes you more comfortable to do so you can pack it with grease.
Steve
Old May 8, 2003 | 11:29 PM
kfoley's Avatar
Car: '85 Z28
I didn't know that.... learn something everyday...
Old Mar 16, 2016 | 03:30 AM
gunwelda_66's Avatar
Car: 84, 85 Camaro Berl. 1999 Corvette.
Engine: 305, 400, LS1 350.
Transmission: 700R4, 700R4, 6 Speed manual
Axle/Gears: Factory
Re: Roller Pilot Bearing or Brass Pilot Bushing??
Agreed. I'll probably go with a Roller Bearing & 1/2 pack it with Mobil SHC 100 High Speed Grease.
The Work Industry that i work in, high speed bearings don't like being overpacked with grease & they tend to get too hot.
Old Mar 16, 2016 | 07:33 AM
big gear head's Avatar
13 year old thread. That's bringing them back from the dead.
Old Mar 16, 2016 | 08:00 AM
Hey, at least he searched.
Old Mar 18, 2016 | 12:45 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Yeah I'm glad people are searching.... I've been guilty of accidentally bumping old threads before, LOL.
For whatever it's worth, I always used bushings.
Old Mar 23, 2016 | 02:27 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I'll never install a roller bearing;
The factory bearing in my 95Z got messed up when my clutch factory disk failed ( @19 Y/O, 85K miles ) and it took FOREVER to remove what was left of it from inside the crank. What would have been a 5-minute removal of an worn 80K mile Bushing took hours of grinding to get it out. A bushing would have NEVER been able to disintegrate like that,..........No Thanx.
I installed a new BUSHING ( as I've always used in the past ) so I will never have to worry about that mess ever again !!!
Old Mar 23, 2016 | 10:58 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
The first pilot bearing I ever installed was in a '68 Z28. I smashed the heck out of it installing it.
After getting it out, I just put a new bushing back in. Some things are just idiot proof by design.
Old Mar 24, 2016 | 12:03 AM
Bubbajones_ya's Avatar
Car: 1998 Viper/1996 Bronco
Engine: 8.0/7.3
Transmission: T56/ZF5
Ha yeah when I first bought my 91, there was a "pilot bearing" installed. Well after taking the transmission down, my input shaft looked like a unique handspun wine glass with all the grooves worn in it and there was a nice steel ring left in the crank. It made it easy to fit a puller tool in there though.
Needless to say, I don't think I'll ever use a pilot bearing on these motors after seeing that. I have a nice brass bushing installed now when I finally got around to putting in a V8 T5 that replaced the old V6 one that was installed.
Hotrodboba400
Dec 10, 2019 07:07 PM
camaro1185
Oct 26, 2015 06:51 AM
sreZ28
Oct 22, 2015 08:21 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
