th-400 rear seal
Old May 6, 2003 | 01:51 PM
camaro_1983_383's Avatar
th-400 rear seal
ok, i need a rear seal for my th-400 but i dont know what vehicle it came out of. when i went into checker, i told the lady at the counter i needed a rear seal for a tubo 400 and she got me a 400 engine rear main seal. obviously, i couldnt get any help there. i do know that it is a short tail shaft and tho yoke outiside diameter is 1.625" and its about 5" long, hopefully this will let you know what tranny i have. i just need to know what vehicle i could tell them i have so that i get the same size rear seal. thanks for the help.
Old May 6, 2003 | 02:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They're all the same.
If you just need an application for them to punch into their computer because they're the all-too-typical parts store peeople that know nothing whatsoever about cars, go get the one for one of my other cars: 74 Chev Caprice 454 convertible.
Old May 6, 2003 | 04:02 PM
thanks for the reply so soon. i need my car this weekend for a trip. i was told that there is also one that is bigger, the long tail has a wider diameter yoke, atleast thats what the driveshaft guy said. but thanks again.
Old May 6, 2003 | 06:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They're all the same. Believe it.
There is such a thing as a Turbo 375, hoewever, that looks alot like a Turbo 400, but has the smaller output shaft, like a 350. Make sure that isn't what you've got. You could get both and just take back the one you don't use.
Old May 7, 2003 | 10:38 AM
how do i know if its a 375 and not a 400? the yoke dimesions are the same as the driveshaft guy read off to me. although he gave me 2 different sizes. i know that the pan is the same shape as a th-400 pan, and the tail shaft is 4". i hooked up the megashifter for th-400 settings and its working fine, when i bought the yoke from the junkyard, i asked for a th-400 yoke. so everything leads me to believe that i do have a th-400, although the mechanic i bought the tranny from lied alot. when i was at checker trying to buy a rear seal, some guy busted out a book for tranny applications, and it had about three different applications for th-400, which varied by year. thanks for the help though, i have one coming at noon today for your caprice. ill let you know if it works.
Old May 7, 2003 | 11:45 AM
Z28Clone's Avatar
Bring to the parts store your old seal. And when you bring it home and it dont fit and they wont take it back, its just a few bucks.
Old May 7, 2003 | 05:58 PM
the one for your caprice worked. thanks alot.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
