Ring And Pinion Q??
Old May 8, 2003 | 09:42 AM
Warrior's Avatar
Car: 98 Camaro/85 Camaro
Engine: 3.8L/ 355 CI
Transmission: Auto/ TH350
Axle/Gears: 3.23 Posi
Ring And Pinion Q??
OK i have an open wheel 85 Z28 with a 5spd... well im looking to buy a new ring n pinion with a posi carrier but i dont know if it will fitt and im nott sure where and how to look to see if it will so im posting this to see if you guys can help... this is what im thinkin about getting ~~> 3.23 ring and pinion gears mounted on a 3-series carrier with posi. it was removed from the 10 bolt 7 5/8 rear with 28 spline axles..... So can anyone tell me if this will fit??? or if i could make it fit somehow???
Old May 8, 2003 | 10:27 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes it will fit in your housing. Your axles however will not fit in it because they have 26 splines. You need the axles from a 90-92 Camaro or Firebird; no other vehicle's axles will work.
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Numbah-1
Oct 2, 2015 08:27 AM
gord327
Sep 29, 2015 10:18 PM
