tranny build up idea, need advice...
Old May 10, 2003 | 02:52 PM
cherrybombZ28's Avatar
Car: 83 Z28 camaro **SOLD**
Axle/Gears: stock
Well, Im getting ready to rebuild the 700r4 in my camaro and a friend of mine, who also has a camaro, gave me some tips. Just wanted to see if it was really worth the extra money... He said I should put 2 extra 3-4 clutch packs in because there is enough room for it, a mild shift kit, a corvette servo, and have holes drilled into the valvebody. Im pretty knew to the scene so I have no clue what any of this means. Any help on the benefits and drawbacks of this setup would be great.
Old May 10, 2003 | 09:25 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
I do not know about the fitting 2 3/4 clutch packs in, but I do suggest if your going to do a rebuild, a 3/4 clutch pack is most important for a 700r4, and i would recommend the raybestos with kodeline coated frictions.
Old May 11, 2003 | 03:34 AM
Pro Built Automatics's Avatar
It's Kolene steels. On the street, we have found the Raybestos Blue Plate Specials do not hold up well. At the track, they due alright. I use Borg Warner Hi-Energy 2-4 bands & 3-4 clutches, in all my builds with great success. They are about 1/3 the price of the BPS's. With the right combination of thin .060 & thick .080 steels, and pressure plates, you can get 7 or 8 .080 BW Hi-E 3-4 clutches in the drum. If you have any questions, let me know?
camaro11j
Sep 19, 2018 08:49 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
hokis
Aug 9, 2015 03:57 PM
