Posi Cone Shims in 9bolt
Old May 15, 2003 | 02:34 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
im gonna shim the posi unit in my rearend. do i have to order the shims from 9bolt.com or is there others i can get easier thatll work just fine?
Old May 15, 2003 | 09:21 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Just installing shims will only work for a short period of time, then the condition will be worse. To do it correctly requires more than just a few shims.
Miles
Old Dec 5, 2005 | 11:58 PM
petes88ta's Avatar
Car: 88ta 305 5spd
For 88 427 camaro
Can you explain what else should be done besides the shims on a 9 bolt assuming back lash,bearings etc look good? I have in my possesion two die set that i was going to rework so I can punch out multipe shims varying thickness,but I may not be able to rework the punch and die sets till Spring time.Could anybody tell me the tolerance on ID and OD and prefered steel(hopefully not blue steel,spring steel). I saw a posting on not exceeding a specific od and Id but I need these numbers to the Thousands of an inch for Tool and Die work.Thickness reqired, I think if my memory serves me well, were .005,.010,& .050 real bitch to cut blue steel at .050 I'may be able to supply freebeis to third gen member but no promises . Thanks PT
KO1
16
Oct 15, 2015 05:00 PM
gord327
Oct 3, 2015 01:25 PM
