Pro 5.0 Aftermarket T-56 shifter. Questions answered
Old May 15, 2003 | 11:32 PM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
The aftermarket T-56 shifter uses a GM T-5 bolt pattern. Unfortunately you can not use a GM T-5 shifter due to the rotation of the T-5 transmission and the shifter handle bent away from the driver. The aftermarket T-56 is straight up.
When I ordered it I said I can use the GM T-5 base but he said no. The ball on the shifter, that contacts the shift rail in the tranny, is a little short for the T-56.
Then he got a shifter base for the Mustang T-56, which I found out has the same bolt spacing as a GM T-5 shifter. He said this base will work in my T-56 with the Pro 5.0 GM T-5 handle.
Well I just got it today and looks like a quality piece and that it should fit perfectly. I can't wait to install it.
Old May 17, 2003 | 11:15 PM
Z_Ghost's Avatar
So on the aftermarket T-56 you used a shifter base for the Mustang T-56 and the Pro 5.0 GM T-5 handle.
Is the shifter base a Pro 5.0 ?
Did you get it in the car yet and how does it fit?
I am getting ready to order my aftermarket T-56 for my car and was wondering about this.
Thanks.
Old May 18, 2003 | 02:56 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
So your saying I need to order a T-56 mustang shifter and put a GM T-5 handle on it? I also ran into this problem. Could I use a mustang shifter handle? Or will that not work?
Old May 30, 2003 | 09:59 PM
Yup that is what the guy at Pro 5.0 told me. It is a 2003 Cobra T-56 shifter, with a T-5 handle. I am also going to install the RobMod to cut down on vibration.
Have not had a chance to install it yet. I am just too busy working on my house now
Old May 31, 2003 | 12:09 AM
Z_Ghost's Avatar
What's a RobMod?
Thanks for the info, I am just about ready to order the aftermarket T-56 for my car and having that info will help.
Old Jun 19, 2003 | 10:31 PM
mhaskell's Avatar
I'm about to swap in my t-56 any more info on your shifter? Is it in? How does it work? Thanks -Mike
Old Jun 20, 2003 | 06:41 AM
Ghost: The Rob Mod is when a piece of rubber is place between the shifter handle and where it mounts to the shifter. Do a search on LS1.com
mhaskell:The tranny is in and it works great. The only problem I had was the Spohn loop cross member and TA combo. After I mounted the tranny the loop hit the TA. I sawed it off and put a different one on.
Cleotiz
Jan 6, 2018 08:56 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
cRoe4
Aug 7, 2015 08:46 PM
