car IDLES differently in D, than it does in 1, 2, or OD?
Old May 16, 2003 | 05:02 PM
Chuck Haynes's Avatar
I noticed that if I have the car in gear with my foot on the brake, it idles DIFFERENTLY in Drive than it does in the other gears?! It's like the car sounds/feels SLIGHTY different, maybe like a 'higher pitched' idle (the RPMs stay EXACTLY the same though). 1st is normal, 2nd is normal, 3rd is a little different, 4th is normal?! Does this make sense?
-Thanks
Old May 16, 2003 | 10:37 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Sorry, but it does NOT make sense to me! The input shaft turns the same speed (0 RPM's) if you're stopped, and idling.
Old May 17, 2003 | 10:34 PM
Does anyone have any ideas?
Old May 17, 2003 | 11:13 PM
JP84Z430HP's Avatar
Car: 84 Z28
I've thought about this on ea little bit, and still haven't come up with anything definite. The only thing I can come up with is it may idle slightly lower (Although I odn't really think it would be noticable) in second, first, and reverse due to the fact that the line pressure is a little bit higher in those gear, therefore creating a SLIGHTLY increased load on the engine. Either you have a REALLY good ear/feel, or your engine is really sensitive to load at idle.
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
