Torque Converter to Flexplate questions...
Car: 00 TA, 91 Formula, 89 RS
I am in the process of swapping my 700r4 (first time attempting anything like this...) I understand that there are three bolts connecting the TC to the flexplate, correct? and that in order to reach all the bolts I'll need to manually turn the engine? Well I was not aware of this, and my serpentine belt is removed from my engine and all of the oil is drained from it (did A/C delete and other things). Is this going to cause a problem with my turning the engine manually? I'm guessing I'm going to have to re-fill the engine with some oil before cranking it? Also do I just take a socket wrench to the bolt at the front of the engine on that big pulley and crank it?
Please answer ASAP, I'm trying to get this thing done!
Car: 4
Engine: 6
Transmission: 5
Originally posted by RB83L69
get a flywheel turning tool.
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I'm in the process of replacing my 700R4. When I removed mine I just cranked on the bolt on the pulley to turn the flywheel. It worked for me. I didn't know about a special tool for turning the flywheel. I am interested in where to get them and how much they cost because I still need to put the new tranny in and I will be removing another one next week to replace a torque converter on my buddies car.
I ended up cranking the bolt on the pulley as well, worked fine for me. Now I'm having an impossible time with the cooler lines.... grrr...
Car: 1985 Iroc-Z
Get a 1/2" line wrench. It's really the only way to get them off. I had to lower the transmission a little to get to them.
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
You are one of the lucky ones! If you must use the balancer bolt, AT LEAST remove the spark plugs...a strap wrench is the best sollution.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Here's the one RB was talking about.
Here's another possible way to rotate the crankshaft.
Either will work fine. It might not be a bad idea to have both in your tool box. After all, there's no such thing as "too many tools."
Car: 1985 Iroc-Z
I think I would be more worried about breaking one of the teeth off the flywheel with that tool than I would about breaking the bolt off the crank pulley.
Engine: 406
Car: '99 HO Z28 / '03 Trailblazer
Originally posted by FyreLance
I've got the tranny lowered and I'm using a 1/2" line wrench, and I still can't get them off........
Engine: 406
They are a B*tch..no doubt about it..but as mentioned lower the tranny as much as possible and plan on short strokes...its even tougher to get them on!..
Car: 1985 Iroc-Z
That's not what I wanted to hear. My tranny still hasn't arrived from Pro-Built yet. Getting the lines off was such a PITA I was really hoping they would go back on easier. Oh well.
I managed to get the lines off okay, just used (small) vice grips and twisted it a few times...
My tranny is officially dropped... now I'm trying to figure out how to get the new one up there....
Stangski09
Nov 14, 2015 01:27 PM
