Will it blow?
Old May 19, 2003 | 07:50 AM
CHRISMAN2000's Avatar
Car: 1991 Camaro Z28
Engine: 350 L98
Will it blow?
Hey guys I really need some better tires. My car won't hook.
So I think I'm going to run some et streets. My question is will my 10 bolt blow? I'm running low 14's. I am planning on getting a ford 9" but I just can wait.
What do you guys think?
Old May 19, 2003 | 01:01 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
it will live as long as you don't go with a big-mombo tire
get an aftermarket torque arm also...
factory sucks.
Old May 19, 2003 | 04:49 PM
Engine: 350 L98
Oh for sure I will. But I'm eventually getting a 9" so I'd have to order it for that rear end. I just want it to hook up a little better for the time being. And seeing how I'm not making huge power yet (evil laugh) I just wanted to know if it would blow the rings.
Oh I forgot to mention I have a TA performance diff girdle with studs.
Old May 19, 2003 | 05:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well, the LS1 cars run 13.2 or so off the showroom floor on the exact same rear end without too many catastrophes; so I'd say if you're as slow as low 14s, you don't have too much to worry about, as long as you're not running a real high stall and a trans brake with wrinkle-walls, or you avoid clutch dumps and speed shifting.
You can tear up a rear end with a 6-cylinder, or you (I) can make it last behind a 400. Driver's choice.
Old May 20, 2003 | 03:17 PM
Engine: 350 L98
Thats what I figured. Oh well if it blows it blows.
Old May 20, 2003 | 04:46 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
you should be good to go.... its when you get into the 12's running slicks that you run into drivetrain issues for the most part.
Old May 21, 2003 | 12:21 AM
Engine: 350 L98
Thanks guys
blackz281le
Jan 11, 2016 07:51 AM
Fanatic1074
Oct 2, 2015 03:47 PM
86IROC112
Sep 28, 2015 08:17 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
90formulaVortec
Sep 3, 2015 09:26 AM
