9 Bolt axle seals
Old May 19, 2003 | 07:55 AM
88GTA383's Avatar
9 Bolt axle seals
How hard is it to change the axle seals in a 9 bolt? Can you remove the axles without opening up the pumpkin?
Old May 19, 2003 | 05:45 PM
toms84ss's Avatar
You dont have to open up the rear end. But the seals are under the bearings on the axles. So you'll have to get those changed while your at it. Machine shop will press the old bearings off and the new ones on for you. By the way. There are two different seals for the axles. Dont mix them up.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
gixxer92
Sep 1, 2015 04:32 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
red90IROCls1
Aug 25, 2015 06:56 AM
