T5 to TH350 swap
Old May 20, 2003 | 09:24 PM
Killogy's Avatar
Car: 87 Firebird Formula
Engine: 355
T5 to TH350 swap
Just wondering what all is involved with switching from a T5 to a TH350 or TH400 since I'll most likely be destoying my T5 with the my new motor.
Old May 21, 2003 | 07:47 AM
85_ZED28's Avatar
Car: '85 Z28
I may have to do this too, ttt
Old May 21, 2003 | 04:19 PM
Mad-Mic's Avatar
Car: 87 Vette 85 TA 82 Z/28
Engine: 3 - 350's 388 400
Transmission: 2-700R4's 1 T56 Setup!
Axle/Gears: 2.59's 3.42's 3.73's
not much except changing out the flywheel, getting your drive shaft length right and getting the anti torque bar fastened to the new tranny. if you go with a th400 you'll have to cut the tranny well.
BTW how much for your T-5 with shifter plate and clutch pedal?
Old May 22, 2003 | 07:56 AM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
Well....I am looking for a T-5 to put the g-force kit into...And my car has a built T-350 now....Anyone wanna sell me a Trans and everything for a manual swap....Or Trade for a built T-350????
Old May 22, 2003 | 04:01 PM
1986redbird's Avatar
just finished doing this very swap, you will need the tranny of course,the flexplate,torque converter,torque arm mount kit from jegs or summit.
depending on which length tail shaft you use you will need the following;
short tail: 3 inch longer drive shaft,longer torque arm,tranny mount that bolt to the forward most 2 holes in the frame.
a drive shaft from an early model car with a th200 will fit both length wise and spline wise as will the crossmember and torque arm.
long tail: the manual components should be able to be reused and all you should need is the torque arm kit mentioned above.
something I forgot about until the last thing is the tranny cooling lines, since your car was a manual it will not have the cooling fittings in the radiator so you will have to come up with something for that. I used rubber hose rated for tranny use for the lines (easier than steel) and insted of buying a new radiator or tranny cooler I reused the A/C condensor (after cleaning it out good). you will also need provisions for the kick-down cable for the carb/TB mount.
Old May 27, 2003 | 08:52 AM
ChellysCamaros's Avatar
OK..here we go..
I have an 84 camaro with 350 backed by a T5...trannys toast
I have an 84 camaro with 305 backed by a 700r4....reverse is gone..
I also have a 78 camaro with a 350 backed by a 350 tranny....
So basically.. I have all the parts to do the swap... What I wanna know is.. can I use the torque arm from the 84/700r4 for the 84/350?
thanks for reading...
ps.. i am a camaro freak.. do not mess with my camaros.. i will throw a wrench at you....
LittleFranks
Sep 17, 2015 12:22 PM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
