got the G-force t-5 info in the mail..
Old May 21, 2003 | 11:26 AM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey guys i got my info packet in the mail from g-force. it seems that for 950 u get 1st-4th gear, then if i am reading it corectly for around 300 more u can buy the strong mainshaft, then they charge 200 for labor not including any little replacement parts. i didn't find any info as to if it came with synchros or not though
Old May 21, 2003 | 01:41 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Just called them about buying an entire tranny from them. They say that it comes with the 9310 High Nickel Steel shaft, and they'll rate it for the 600 HP.
I got thier info in the mail too. But they say no warranty- so I don't know...
Old May 21, 2003 | 07:36 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
how much for the whole trans?
What do they actually do with the trans? Do you send your T5 in for upgrades?
Old May 21, 2003 | 07:49 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Yeah, more info please. I'd love to go manual, but if its a $2,500 swap then I'll spend about $2000 on a Pro-built 700r4, and a new stall.
Old May 22, 2003 | 12:29 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Here's what my info sheet says for the synchronized kit.
List Price
G-Force T-5 Synchronized Upgrade Kits
True bolt-in synchronized replacement gearsets capable of handling up to 600 streetable* horsepower
Synchronized Ratios:
2.94
1.94
1.34
1.00
.59 or .73
Kit Prices (you build it using your trans):
1st to 4th gear sets,
includes 1st, 2nd, 3rd mainshaft gears, 26 spline input shaft with input drive gear (4th), complete cluster shaft with gears 1st, 2nd, 3rd,and cluster drive gear (4th).
$950
Overdrive gear set (.80 when availible),
$360
Upgraded Mainshafts (not included in gear kits),
ASTM 9310 High Nickel Steel : $295
ATSM 4340-300M Thru Hard Premium Alloy: $495
Send us your T5 and we'll install the kit for you (labor only): $200
Does not include rebuilt/small parts kit
New T-5 with G-Force gearkit already installed: $1945
*Note
Those prices could fluctuate, please call them or send for a new info packet for current prices.
Old May 22, 2003 | 12:47 PM
kane91z's Avatar
Car: 91 Z28
Engine: 5.7
I thought the main problem with the T5 was the actual housing?
Old May 22, 2003 | 12:54 PM
kfoley's Avatar
Car: '85 Z28
Well, I'm no expert, but I would imagine that until 600 or so hp it's the gears, then after that it must be the case.
Old May 22, 2003 | 05:20 PM
Tom84L69's Avatar
Car: 84 Z28
For $1945 you can get a new T56...course it probably isn't good for 600 hp. And does "streetable" mean not for racing?
Old May 22, 2003 | 11:36 PM
kfoley's Avatar
Car: '85 Z28
I think T56's are good to about 450 hp or so. Streetable means a car with drag radials and a moderate clutch pushing 600 flywheel hp. Basically they're saying it's not a full out racing tranny (although they do have tranny's for that). It's more for street/strip use, but it can handle some decent power. You can use it for racing, but it's not reccomended for a dedicated drag car with slicks putting out some good power. For those cars they have trannys that can handle like 1000hp or something crazy like that.
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
