rebuilt /install shift kit
Old May 22, 2003 | 11:07 PM
man_of_steel27's Avatar
Car: 92 RS - For sale
Transmission: 700 R4
Axle/Gears: yup, it has a peg leg
ok what would be the diifference. if i needed my tranny to be rebuilt
would i have to get it rebuilt first then get the shift kit, or would getting the shift kit be the same. please shed some info on this
700r4 wanting to get trans go shift kit
thanks
Old May 23, 2003 | 08:01 AM
ede's Avatar
ede
you can install a shift kit without doing a rebuild, or you can do a rebuild without installing a shift kit, or you can do both at the same time.
Old May 23, 2003 | 09:08 AM
but if i do the shift kit install would it be like doing a rebuild?
for instance instead of getting it rebuilt and i have the shift kit installed would it be the same as rebuilding it except for the different shiftpoints etc..
so would it be pointless to get it rebuilt then get the shift kit installed? or is necessary to have the tranny rebuilt then get the shift kit.? b/c my tranny does need to get rebuilt.
Old May 23, 2003 | 09:22 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
first off, a tansgo kit does not take the place of a tranny rebuild.
Is your tranny having problems?
If it is fine, then just get the transgo kit istalled for better shifts.
If the tranny is slipping or having other problems, Have it fixed first. There is no since in putting in the trango kit into a slipping tranny.
hope this helps.
later
Old May 23, 2003 | 09:41 AM
Briansz28's Avatar
If the transmission needs rebuilding, get it rebuilt and add the shift kit at the same time. It will already be apart & clean-easier to work with. Are you doing the work yourself?
The shift kit won't replace a rebuild, but some of the components are replaced with the shift kit-*****,plates, springs, gasket.
Old May 23, 2003 | 10:21 AM
thanks thats what i needed to know
ok i will get it rebult first
no i prob wont do it my self auto trans to difficult.
thanks fo all the info:lala:
Old May 23, 2003 | 11:05 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
No problem. Anytime.
Just get the trans in good working order. It will make a big difference. You might talk to the shop doing the rebuild and have them install the trango kit at the same time. They should be happy to do it for you. Might want to think about a stall converter swap also. If you can afford it. Tranny rebuilds can run into some good money.
good luck
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
g.l.mos
Aug 22, 2015 12:02 AM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
