How can i break the flexplate bolts loose?
Car: 90 Camaro RS
Engine: 305 TBI
how can i break the (6) flexplate bolts loose.
Torch? What kind?
I already broke a taiwanese 9/16 6-point socket, and my craftsman 12-point 9/16 keeps trying to strip the bolts.
Rick
Torch? What kind?
Rick
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Have you tried soaking it with penetrating fluid? If not, I would soak it every few hours for a day or so and then try it again.
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
I wedged a pipe in the flywheel gear and that held it in place and then used a cheater bar.
Car: 92' RS
Engine: LO3
Axle/Gears: 3.70 9-bolt
Just before putting another socket on it heat it up just before with a map or benzomatic torch, something along those lines. It is amazing how much easier it makes loosening bolts. Trust me
Car: `86 SS / `87 SS
The 14mm socket trick is a good one. So is the recommendation of heat.
On tight bolts, sometimes I find that tightening them a bit before removing them loosens the threads sufficiently to be able to loosen them.
I don't use Crapsman sockets.
Car: 90 Camaro RS
Engine: 305 TBI
thanks for the help guys.....after several hours of pounding i was able to get all 6 bolts off with a 1/2 impact driver, 1/2 6 point 9/16 impact socket, and 2.5lb sledge. A friend and I rotated until all bolts were finally free.
The bolts were surprisingly clean and twisted off smooth as silk....all of them.
My new McLeod flywheel is going on with new 3/4 inch bolts that should make removal easier next time.
The one thing that really seemed to help break those bolts loose was Black Sabbath. I knew it would come in handy. It really set the tone for some sledgework.
now i just have to figure out how to get that darn pilot bearing in ??????
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Stangski09
Nov 14, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
