tranny swap clarification
Old Jun 2, 2003 | 01:36 PM
miked's Avatar
Swapping a 700r4 from a firebird with a 2.8L V6 into a TA with a 305 cannot be done due the the bellhousing difference correct? Not even with any adapter out on the market. Just wanted to be sure. Thanks.
Old Jun 2, 2003 | 01:52 PM
ede's Avatar
ede
there maybe an adapter out there but i don't know of any. you're correct the bells for a 60*v6 are differant then SBCs, BBCs, and 90* v6
Old Jun 2, 2003 | 07:21 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
You should be able to change the bellhousing on the 700R4. Right?
Old Jun 3, 2003 | 08:59 AM
miked's Avatar
I didn't think that you could on a 700r4. If you could that would be nice for me right now but I don't think you can. Hopefully someone else could clarify.
Old Jun 3, 2003 | 11:54 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
You may be right about that. I'm not real sure.
Old Jun 4, 2003 | 05:39 AM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
yes there is probably an adapter......but being that the 700 bell housing is part of the case its self the v6 one wont work on a v8
Old Jun 4, 2003 | 05:28 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
There may be an adapter for it (700r4's don't have separate bellhousings), but I wouldn't recommend it. The internals of 60* v6 700r4's are different than their v8 counterparts. Not only will you be swapping in a unit not equipped to handle the extra duty of the v8, but I'm guessing the unit is used as well??
camaro11j
Sep 19, 2018 08:49 AM
gta90
Sep 15, 2015 04:00 PM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
