Rotors rusted to axles
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Well the title pretty much says it all. I've tried beating on the rotor 'hats' and spraying witha good penetrant, but nothing seems to work. I'm open to all pretty much all suggestions, but note that the axle may not have c-clips. Also, I have 2 axles both with the same rusty rotor condition.
is it the front or the back? If it is the front, you need to take off the hub. My backs were rusted on pretty good. I beat my rotors with a sledge hammer and ended up putting a dent in them. They would not come off. after like 3 hours they finally broke loose.
Car: '88 Formula
I understand the first 2.... but CO2? Please explain! They are the rears.
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
When I did my drum to disc conversion, the salvage yard rear end assy. had some pretty rusted on rotors... I used a large-jaw gear puller, tensioned it up real tight, then a good rap with a hammer and they popped right off...
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
dbrochard
Sep 19, 2015 08:13 PM
rudolphschenker
Sep 4, 2015 02:41 AM
