Typical life of a 700r4?
Old Jun 9, 2003 | 01:08 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I've got 120k miles on my tranny, and it's running flawless.
I was just wondering when I should start to be concerned about mileage.
Should I switch to Synthetic ATF or keep the standard fluid changed regularly?
Old Jun 12, 2003 | 12:34 AM
rumpilstiltskin's Avatar
If it is still running flawless youre are doing something right, keep up whatever it is youre doing.
Old Jun 12, 2003 | 01:19 AM
Pro Built Automatics's Avatar
If the transmission oil looks & smells ok, leave it alone.
Old Jun 12, 2003 | 07:36 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
And if it doesn't, leave it alone also.
Old Jun 12, 2003 | 09:39 AM
RJR99SS's Avatar
i have one right now that has about 190k miles on it. It has a little hesitation going into first gear, but thats all i can find wrong with it.
i'd say if you have a trans cooler, change the oil often and dont go crazy with it, they'll last forever.
Old Jun 12, 2003 | 04:22 PM
SlowMaro's Avatar
forever or until your front seal /pump decided to die in the same die --like mine-- and you dont realize its happened until you cant get into third. im to the point where i wanna check my fluids at every stop light heh
Old Jun 12, 2003 | 06:40 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
mine just bit the dustwithyonly 100k (167km) on it
Old Jun 12, 2003 | 08:24 PM
408TA's Avatar
HEAT is the #1 killer of 700r4's ; the other is hitting reverse at 50 mph.
Old Jun 12, 2003 | 10:55 PM
SlowMaro's Avatar
speaking of heat.....whats a good tranny cooler??? where is a good place to mount it???
Old Jun 13, 2003 | 12:40 AM
Firebird355's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
i have a HAYDEN, and mounted it in front of my radiator, they give you straps to attach it. You can buy them at auto zone, they are behind the counter.
Old Jun 13, 2003 | 11:01 AM
SlowMaro's Avatar
in front of the a/c condensor????
Old Jun 13, 2003 | 10:14 PM
Car: 1991 Camaro RS
Engine: 305 TBI
well yea you can do that too, i took off my air conditioning. when you buy the kit it shows you different places to mount it. the one that i bought was $25 i think
Old Jun 14, 2003 | 01:56 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
A tranny cooler is an excellent, excellent investment for a 700R4 especially if you race it on the weekend or live in a hellish heat box like Las Vegas. I had no idea they sold them at Autozone, I'm going to go get one very soon.
Old Jun 16, 2003 | 11:20 AM
bigals87z28's Avatar
Car: Check The Sig
should of gotten one before i left strauss... dam it!
Old Jun 16, 2003 | 11:27 AM
SlowMaro's Avatar
wooohoo FIANLLY got my reman tranny installed, after they screwed me outta 100 additional bucks on parts they claimed i needed, total install bill...350, as opposed to the 240 i was quoted....but i didnt feel the urge to argue. ill take em to small claims court though heheh. itll learn them to CALL before they do any additional work. *not that they called one single time, not to tell me any problem they had I.e. flywheel and starter was trashed. didnt even call me to tell me the car was done!! wtf....oh well....if anyone lives in SC never go to hills transmission.
Old Jun 20, 2003 | 06:12 PM
tpi_roc's Avatar
I had a hayden cooler on mine along with:
2,500 rpm stall
vette servo
B4C WOT upshift valve
shi t kit (No i didn't miss the "F")
Mine lasted about 25,000 miles.
Old Jun 21, 2003 | 12:25 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
they last on average about 100K behind 350's.
Old Jun 21, 2003 | 02:28 PM
WS6Formula305's Avatar
Car: '88 Firebird Formula
Engine: 360hp/417ft. lb. 350
Transmission: Pro-Built Street/Strip 700R4
I just put a 360hp 350 in front of my 161k mile tranny. Please pray for me.
Old Jun 21, 2003 | 02:44 PM
Car: 1988 IROC-Z
i will be praying.....:hail:
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
David Frans
Oct 31, 2015 08:12 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
