Speedometer Sensor
Old Jun 10, 2003 | 03:50 PM
trickedout02's Avatar
Engine: 302 5.0
Speedometer Sensor
How do I replace the Speedometer Sensor on my V6 700R4 tranny, since it doesn't have Speedometer Cable??? I have a 91 Camaro RS 3.1L v6..... Any info on the difficulty and pulling anything out, please post..... Thank U
Old Jun 10, 2003 | 07:12 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
Re: Speedometer Sensor
im "assuming" the tranny is the same as my 700r4. The electronic speedo is on the tailshaft. It has one small bolt on the drivers side, and a plastic plug. You should be able to get to it without much trouble. Once you take that bolt out, it will jus slide right out. If you need to change the gear in there, then you will need to pull the tailshaft off (lots more work).
hope this helps...
$750 L98
Feb 1, 2025 02:25 PM
Elephantismo
Feb 13, 2019 12:51 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
TrevinE
Sep 14, 2015 03:20 PM
