82 FIREBIRD SE 200c TRANS LEAK HELP !!
Old Jun 11, 2003 | 04:24 PM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
HI I HAVE AN 82 FIREBIRD S/E WITH V8 AND IT HAS A BAD AUTOMATIC 200C TRANS LEAK COMING FROM THE INSPECTION COVER.WAS TOLD IT CAN BE A NUMBER OF THINGS,CAN ANYONE HELP OUT?.I GOT A QUOTE FROM A PLACE FOR $330 TOTAL FOR A USED 200C TRANS INSTALED WITH CORE EXCHANGE.IS THAT A GOOD PRICE ? PLEASE HELP !!!
Old Jun 11, 2003 | 04:32 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
front seal, about a three dollar part...
ive got a rebuilt thm200c from my 82 that id sell for 125..... new converter and everything,....
dunno how far away you are though...
welcome ot forum!
Old Jun 11, 2003 | 05:04 PM
On Probation
200c trans
Cool thanks man for the info.I live in oklahoma.Trying to save my 82 firebird s/e from rotting away.Would you ship the trans ? let me know i got a cheap freight company that might be able to pick it up.If so ill take the trans for that price.thanks
Old Jun 13, 2003 | 09:44 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
You might want to consider a TH350 rather than putting in another 200C. The 350 is a lot stonger, it's an easy install for your car and might even be cheaper. It can also be built to TH350C spec in which case you will still have the lock up feature.
Old Jun 16, 2003 | 04:44 PM
On Probation
trans choises
which one of these can i put in my my 82 s/e with 200c automatic please help thanks ?
A.T., TH350, w/multifit case, 1 wire lock-up plug harness
A.T., TH350, w/multifit case, 2 wire lock-up plug harness
A.T., TH350, w/multifit case, 3 wire lock-up plug harness
A.T., TH350, w/o multifit case; w/Chev bolt pattern; 1 wire lock-up plug harness
A.T., TH350, w/o multifit case; w/Chev bolt pattern; 2 wire lock-up plug harness
A.T., TH350, w/o multifit case; w/Chev bolt pattern; 3 wire lock-up plug harness
A.T., TH350, w/o multifit case; w/o Chev bolt pattern; 1 wire lock-up plug harness
A.T., TH350, w/o multifit case; w/o Chev bolt pattern; 2 wire lock-up plug harness
A.T., TH350, w/o multifit case; w/o Chev bolt pattern; 3 wire lock-up plug harness
Old Jun 16, 2003 | 04:52 PM
On Probation
trans choises
Old Jun 16, 2003 | 07:27 PM
RustBucket's Avatar
While you've got it down and out,check the torque converter. It may be cracked at the weld where the snout meets the converter body. Take it from someone who r&r'd a700r4 3 times thinking I'd done something wrong with the seal.
Stuff a rag in the snout and stick an air blow gun in there and GENTLY GENTLY GENTLY, ( did I mention GENTLY?) Bump a little air into the converter. You'll see fluid bubble out from the weld if it's indeed cracked. The converter for the V6 700r4 was a little over a hundred bucks. You'll also need a bunch of tranny fluid.
colton_carlson
Mar 8, 2019 12:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
mizz0313
Aug 12, 2015 06:45 AM
Exxon Limited
Aug 9, 2015 08:13 PM
3rdgenparts
Aug 6, 2015 09:03 AM
