1le aluminum driveshaft
Old Jun 12, 2003 | 06:26 AM
cerice's Avatar
Is it possible to buy a 1LE aluminum driveshaft as an after market produce. I was told you could, and if this is correct who would sell this type of driveshaft and how much would it cost.
If not what would be a good aluminum driveshaft my 89 iroc, and how much would it cost.
Old Jun 12, 2003 | 06:59 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
If I understand your question, yes you can buy a 1LE Dr shaft new.
It is GM p/n 10085375 and GMpartsdirect sells them for $249.
Some other suppliers sell Aluminum Shafts also but for a lot more money.
Old Jun 12, 2003 | 07:01 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
check out www.dennysdriveshaft.com
He is a local guy for me, however, he ships all over the world.
Great product, top notch. He quoted me a price for an aluminum shaft of $310 good to 700HP. The Steel version $280. The steel ones are gaurenteed never to twist or break.
Old Jun 12, 2003 | 07:44 AM
cerice's Avatar
Thanks a lot that is very helpful. More opinion would also be helpful.
Old Jun 12, 2003 | 04:31 PM
Cool Runner's Avatar
Car: 86 Trans Am WS6
Do a search for the LS1 4th gen drive shaft. It fits our cars and IIRC it's cheaper/beefier than the 1LE driveshaft.
Old Jun 12, 2003 | 11:42 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Do all 4th gens come with aluminium driveshafts?
Old Jun 13, 2003 | 01:08 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I'm pretty sure 1LE and LS1s with 3.23s got an aluminum driveshaft.
Old Jun 13, 2003 | 08:41 AM
cerice's Avatar
does anybody else know anymore information of the 4th gen LS1 driveshaft. Thanks for the information cool runner, I did not know that.
Old Jun 13, 2003 | 09:13 AM
DJP87Z28's Avatar
Any year 4Th Gen Aluminum Dr Shaft will fit on all 3rd Gen cars both for a Auto & Manual. Size for 1LE is 2 3/4" and 4th is 3" in diameter. The 1Le is lighter of the two. Only advantage is lighter weight and possible elimination of driveline vibrations at speed.
Old Jun 13, 2003 | 10:03 AM
cerice's Avatar
would anybody know a part number for the LS1 aluminum driveshaft, I would like the check the difference in price. I know the 1LE is $250.
Old Jun 13, 2003 | 11:52 AM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
try e-bay......do a search on camaro drive shaft thers usually some aluminum ones on there
Old Jun 13, 2003 | 12:13 PM
This is as much as I know so far. I'll keep searching and update as I find more info.
Z28DJP1987:
Folowing are the Dr shaft diameters (OD):
Code:
DS		Material	Size		Part #		Price
Stock		steel		2 1/2"
1LE		Alum		2 3/4"		10085375	219.83
LS1		Alum		3"		12564003	239.00
LPE		Alum		3 1/2"				299.00
formul8!!:
The steel weighed 15.5lbs and the aluminum weighed 12.5lbs.(1LE)
Old Jun 13, 2003 | 01:24 PM
DJP87Z28's Avatar
The P/N is 12564003 for the LS1 Aluminum Dr Shaft. And I belive its $20 cheaper then 1LE, but don't quote me. These shaft appear on e-bay all the time, but don't bid over $150 for them.
Got mine their for $110 because the seller didn't know what he had.
Old Jun 13, 2003 | 02:18 PM
cerice's Avatar
Thanks a lot for all the information and help that everybody has give. The thing was that I posted this thread a couple of days ago, and when I found out the 1LE part number I ordered it. This morning the 1LE drive shaft was delivered, and then I start getting all this information on the 1LS driveshaft. The thought I had made a mistake. However, the 1LE driveshaft is cheaper than the LS1 and for my application it will work great. However, on ebay there are two 1LS drive shafts being bidded on one is for $120 with 1 day left. The other is for $51 dollars with 3 day left. This is if anybody is interested.
Old Jun 13, 2003 | 05:27 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
does anyone know if a 4th gen or 1le alumin driveshaft fit in a 82 camaro with a th350 tranny?
Old Jun 13, 2003 | 06:26 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
No it will not. The 350 is shorter overall. A stock 200C driveshaft will fit though.
Linson
Oct 24, 2025 02:00 PM
loud91rs
Oct 5, 2015 10:05 PM
