break in on reman tranny??
Old Jun 12, 2003 | 04:16 PM
SlowMaro's Avatar
so do i have to break this sucker in? use any special fluid ,and precautios?? when should i drain the fluid and swap out the filter??? its a GM Reman. tranny.
Old Jun 14, 2003 | 03:14 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Slap it in and go. There is no real "break in" period or procedure. No special fluid is required, just change it at 30K.
Old Jun 14, 2003 | 03:38 PM
Pro Built Automatics's Avatar
Make sure the fluid level is correct, and the TV cable is set right. Go about 10 miles shifting it manually, recheck everything, go out and do approximate 1/2 throttle acceleration through the gears, and if everything feels ok, then try a WOT run, if anything does not feel right (long slide 1-2 or 2-3 shifts, 2-3 shift flare, etc.), get out of the throttle immediately. If everything feels ok, good.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
apie2546
Oct 16, 2016 02:24 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
