Help!! New Tranny- Od Not Working!!
Old Jun 13, 2003 | 01:33 AM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
I just put my rebuilt tranny and TC in and overdrive is not there. it takes a second to kick in if it is in Drive, but 1st and 2nd seem to work ok. Also the check engine light came on. while i was driving it. OD is like nuetral. Please help any ideas. ASAP.
Thank you
Old Jun 13, 2003 | 01:56 AM
Car: 1990 Iroc-Z
check engine code
the code it's throwing is 24.
Old Jun 13, 2003 | 02:46 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Code 24 is the Vehicle Speed Sensor. Make sure you plugged speedo cable into the transmission. If it isn't then you are probably losing fluid which will cause it not to shift correctly.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
