Capacity
Old Jun 14, 2003 | 02:43 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
Capacity
How many Litres does a 700R4 transmission hold?
No quarts, pints or any of that stuff.
Litres only please.
Also--I am having my transmssion rebuilt--should I use synthtec oil? Benefits?
thanks
Old May 19, 2004 | 10:33 PM
copperhead110's Avatar
1 quart = 0.946 liters (thats marked on my quarts)
I need to know how much a transmission holds also.
I would like to know how much it holds total and how much I'd have to add after a filter change.
I've added 6 quarts after changing the filter and gasket. There are no apparent leaks and it isn't puddling on the floor.
If I wasn't in a hurry and let the tranny drain for a couple of days would I need more fluid? NAPA sold me 5 quarts and said that would fill it up.
thanks...
now back to searching.....
Old May 19, 2004 | 10:59 PM
By searching for "tranny and quarts" I found this:
>If all you're doing is taking a running trans and dropping the >pan, it's around 4-5 quarts.
>If you had a brand-new trans and converter, it would take >around 11 quarts.
>Do your work; add about 2 quarts; start the motor and add >about 2 more; check and top off.
No wonder search doesn't work for me. I don't use enough slang!
Hotrodboba400
Dec 10, 2019 07:07 PM
krisb410
Mid-Atlantic Region
Mar 11, 2016 09:21 PM
rubyred88
Sep 17, 2015 02:19 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
mike1986fyrbird
Theoretical and Street Racing
Nov 26, 2002 09:11 AM
