Tranny slipping?
Old Jun 16, 2003 | 11:17 AM
bigals87z28's Avatar
Car: Check The Sig
Tranny slipping?
Please can someone describe what a tranny slip would feel like? I dont have one, but then again i dont know what it feels like so i might be slipping in all 4 gears!! My only problem is a tranny leak. I am always at the add line... not lower or higher!! im getting a new alum trans pan soon, i hope to have it before TGO nats! please help me?
Old Jun 16, 2003 | 08:57 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
Re: Tranny slipping?
a "slip" is when the car is shifting gears, and it feels like you put it into neutral before the next gear. the car will rev, but not pull. sometimes it won't be very noticable. for instance, my car would slip at WOT from 2nd to 3rd. when i would get at the top of 2nd gear, it would take a second to kick into 3rd.
with my nice rebuilt piece of **** i ordered from ebay, 1st and 2nd shift ok, then when i get into 3rd, i have to rev it pretty high to get the car to move. a very noticable slip.
hope this helps. im sure someone else here could explain it better.
Old Jun 16, 2003 | 10:15 PM
Car: Check The Sig
ok, its not slipping... its just lazy! hehe mine feels when it shifts into 2nd that it just kinda does it, not as firm as 2-3 or 3-4, but is firm when i drive in D
Old Jun 16, 2003 | 10:58 PM
Car: 1990 Iroc-Z
you should check out the transgo shift kit if you want some firmer feeling shifts. it'll be a noticable difference in shifting.
i had a b&m stage2 shift kit installed in my tranny and it would chirp em goin 1st to 2nd...but i wouldn't recommend the b&m kit. I've heard alot of people on here has problems with it. (not to mention my tranny died 6 months after install), but i heard transgo makes one that will probably extend the life of your tranny and firm up your shifts.
later§..
edited for her pleasure.....ewwww.
Old Jun 16, 2003 | 11:01 PM
Car: Check The Sig
thanks man. I got a Vette servo not to long ago and plan on putting that in next month. that should increase the pressure on the 1-2 2-3 more to where i can feel it! When the trany is done with, im gunna get a new one from TCI or a pro shop. I see them for a little more then to rebuild mine and theres can hold up to 450 ft lbs
Old Jun 16, 2003 | 11:02 PM
Car: 1990 Iroc-Z
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
jrdturbo
Mar 31, 2016 02:58 PM
bjpotter
Oct 4, 2015 07:48 PM
camaronils
Sep 20, 2015 02:57 PM
IROCZ1989
Sep 4, 2015 11:54 AM
