external tranny cooler question
Old Jun 16, 2003 | 08:36 PM
SlowMaro's Avatar
ok so what goes where.....what i i mean is, which line is the tranny fluid entry, and which is the exit, on the radiator, .....top is entry, bottom is exit?? just hook the external tranny cooler up like that????
Old Jun 16, 2003 | 10:36 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yep. Many people disagree on what if the best way to install a transmission cooler in conjunction to a tank cooler. I personally use the coventional (correct) method, mostly..... Top line to radiator leave alone. Cut the bottem return line and run it to the external cooler top feed and run the external cooler bottem return back the the transmission return line. Some people like to have the trans warm up quicker but want the extra fluid capacity so they run it the reverse makes no sence to me.
84z96L31vortec
Aug 20, 2017 12:16 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
TreDeClaw
Aug 14, 2015 06:58 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
