INstalled corvette servo..1-2 still soft....2-3 firmer??
Old Jun 20, 2003 | 12:43 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
I installed the corvette servo and .5 boost valve but the 1-2 shift still feels soft. Did I do something wrong?? Funny thing is the 2-3 shift is firmer tho......
Old Jun 20, 2003 | 01:03 PM
Guest
Guest
Posts: n/a
did you reset the TV cable?
Old Jun 20, 2003 | 01:14 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
yea...reset the cable still the same....
Old Jun 20, 2003 | 02:17 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
you need to change the 1-2 accumlator piston spring. hopefully some one will chime and let you know what color spring to use.
Old Jun 20, 2003 | 02:24 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Is that the spring inside the 1-2 apply servo that I had to change from the stock servo to the new servo. In the instructions it says to install a blue spring along with the stock white spring but the kit I got had no new springs. I instaled the stock spring with the stock snap ring even tho it says to discard the snap ring. Any more help on where to get this spring???
Thanks!!
Old Jun 20, 2003 | 02:36 PM
Car: 1988 IROC-Z
the 1-2 accumlator piston spring located by the valve body not the servo. it's probably broken.(that's very common) if it's not it still should be changed. the stock one sucks.
here's a pic.........
Attached Thumbnails INstalled corvette servo..1-2 still soft....2-3 firmer??-picture1s.jpg
Old Jun 20, 2003 | 04:29 PM
Pro Built Automatics's Avatar
Get a white or plain "flat" wound spring in a 1990 & up unit (not the orange tapered) and install it with washers underneath the piston, so that the spring comes out of the hole by about 1/16 -1/8 of an inch, a slight preload is all you need. This will firm up the 1-2 WOT shift.
Old Jun 20, 2003 | 05:04 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Probuilt what spring are you refering to the one in the servo was already white or the 1-2 accumulator spring mystikkal_69 is talking about?? Where can I get these springs and where is the accumulator spring located valve body? Do you have anymore pics?
Old Jun 21, 2003 | 03:31 AM
It is the spring pushing against the piston in the aluminum housing (2nd gear accumulator) held down with 3 bolts, next to the valve body.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
toronto formula
Nov 10, 2015 06:17 AM
drathaar907
Aug 6, 2015 04:20 PM
