trans shifts firm 1-2 for about 20 min
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
My trans (700-r4) shifts like it has a kit in it from 1st to 2nd till I go about 15 or 20 miles then shifts soft (no slip) after that! What's up? would a tranny cooler keep it shifting firm? I've never had a tranny act like this before, any help would be appreciated.
Car: 88 formula WS6
Engine: 305 Lo3
I don't have any problem with overheating, matter of fact, I just switched back to a 195 deg. therm. from 180 and put a new radiator in (blew end tank on old one in auto-cross) last week. Don't get me wrong, I'm not complaining about tranny, it works just fine, but it would be nice if it would perform like that all the time. It's like the old days with the dial a shift vacuum control. I'm sure it would bark the tires if I had lower gears, or more than 180 horses, but the 2.73s and 235-55-16s bite pretty good. One would think that it would shift better after it warms up (what with expansion and all) or maybe when it's cool (contraction) beats me! Maybe I should service the darn thing (don't filters flow better cold than hot?) I'm not sure what controls line presure on 700-R4 (modulator, servo, shift gov, cable, computer?) I do know, it shifts at 4500 RPM 1-2-3 with no WOT shift to 4th in OD position, or 5000 if I hold it and shift manualy ( don't take it any farther, not much power beyond 4500). 88 formula 305 LO3 tbi 3in cat back ACCEL cap, rotor, 8mm wires, 4 deg in. timing A-C rapid fire plugs do real good job. Removed cover on offset scoop to extract heat, removed collar inside stock air cleaner and used smaller cover (same diam. as filter) to create an open element.
colton_carlson
Mar 8, 2019 12:21 PM
mdtoren
Aug 16, 2015 05:45 PM
dhonda200
Aug 11, 2015 11:50 PM
