Rearend Specs on 3rd and 4th
I need help finding out what car has what kinda rear end in it and if it gots posi or not. I have been trying but have been having problems with the decoder and can't find a 4th gen deconder thats in english. I just got back from the junk yard and wrote down all the vins and specs on all the f-bodies at teh yard. heres a list of 4th gens:
2g2fv221k2227479 should be a 97 red auto firebird and that K could be an x.
1g1fp2314ml119402 I think this on was a 4th gen bird
2g2f5223752240635 purple 95 bird v6 it looked like was in it b4
the rest should be all 3rd gens:
Here are the results for your query on: 1g2f8752fn205216
Made in: United States
Manufacturer: General Motors
Make: Pontiac
Carline Code: F-Body
8 is NOT a known code for the Carline Series!
7 is NOT a known code for the Body Type!
5 is NOT a known code for the Restraint System!
2 is NOT a known Engine Code!
f is the CHECK DIGIT
Model Year: 1992
2 is NOT a known Assembly Plant code
Production Sequence: 05216
Here are the results for your query on: 1g1fp2150hl11795
Make: Chevrolet
Carline Series: Camaro (all models)
Body Type: 2 door coupe (hatchback)
Restraint System: Manual belts
5 is NOT a known Engine Code!
0 is the CHECK DIGIT
Model Year: 1987
Assembly Plant: Van Nuys
Production Sequence: 11795
Here are the results for your query on: 1g2fs23d3n1214868
Make: Pontiac
Carline Series: Firebird
Restraint System: Manual belts (driver inflatable)
d is NOT a known Engine Code!
3 is the CHECK DIGIT
Model Year: 1992
1 is NOT a known Assembly Plant code
Production Sequence: 214868
Here are the results for your query on: 1g2fs21g2jlq49713
Make: Pontiac
g is NOT a known Engine Code!
2 is the CHECK DIGIT
Model Year: 1988
Production Sequence: q49713
a is NOT a known code for the Make!
p is NOT a known code for the Carline Code!
h is NOT a known code for the Restraint System!
x is NOT a known Engine Code!
e is the CHECK DIGIT
Model Year: 1990
Production Sequence: 29195
Here are the results for your query on: 1G2AW87H7DN232976
Make: Pontiac
Carline Series: Trans Am
Engine Code: 305 ci V8 LG4 (1982-1984)
7 is the CHECK DIGIT.
Model Year: 1983
Assembly Plant: Norwood
Production Sequence: 232976
*3.23 I think!
Make: Pontiac
Model Year: 1992
Make: Chevrolet
Model Year: 1987
Make: Pontiac
Model Year: 1992
Make: Pontiac
Model Year: 1988
Model Year: 1990
Make: Pontiac
Model Year: 1983
*3.23 I think!
Car: Take
Engine: Your
Transmission: Pick
Your '95 bird has:
GU5 - 3.23 REAR AXLE RATIO
J41 - PWR, FRT DISC, RR DRUM, CAST IR
and does NOT have Limited Slip
Your '97 bird has:
G80 - LIMITED SLIP
J65 - PWR, FRT & RR DISC
I gave up on the rest of your VIN's, they are incomplete, incorrect and just flat out encrypted. Did you notice that half of the info doesn't come up when you ran them through the VIN decoder? Did you write these on the back of your hand with a magic marker or something????
Your '97 bird has:
G80 - LIMITED SLIP
Well my sister was the one writing all the vins down
so I'm sorry if they are all messed and I noticed that they were like that also. What rear would you guys suggest I put in? The guy said that the disc rears would be a lil more like $250 and the thridgen rears would be about $150. I currently have drum 2.73 on the back right now thats how my car came.
so I'm sorry if they are all messed and I noticed that they were like that also. What rear would you guys suggest I put in? The guy said that the disc rears would be a lil more like $250 and the thridgen rears would be about $150. I currently have drum 2.73 on the back right now thats how my car came. Supreme Member
Car: Take
Engine: Your
Transmission: Pick
I would spend the $250 and get the one from that '97 Trans Am. It has 3.23, Limited slip, and good rear disc brakes. You could pay $250+ just trying to convert your existing rear to later style brakes, but your getting the rest of the rear end as well. That would be my choice. I would try and get the emergency brake cables as well.
Whats so special about the disc breaks anyways, I know their lighter and are a lil better but what else? Also is that limited slip thing the same as a posi? And how much harder would it be to put the disc instead of the drum, would one take longer that the other since I currently have drum stock?
rudolphschenker
Sep 4, 2015 02:41 AM
