Which is the tranny of choice
If you want something reliable, and and take horsepower, check out http://www.pro-built.net/index.cfm?f...t&productid=35 Let me know if I can be of help?
Car: 2007 Volvo S60R, 2005 Audi A4
Engine: 300HP 2.5L I5, 200HP 2.0L I4
Transmission: TF-80SC, Getrag 6 speed
Axle/Gears: 3.33:1, 3.54:1
Pro built,
I am wondering why you don't have 2004R's offered--does this trans have some disadvantages or is there just no demand for built 2004r's?
Car: 92 Camaro RS
Engine: 355 94 p/u motor
Transmission: 700R4 With TCI kit
The 200's sucked bad, and I've heard some horror stories about the 700R. The one I haven't heard anything bad about is the new 4L60e(I think that's the name of it) Its the new 4 speed O/D that's put in the 4th gen cars. You'll get another gear out of it, and I heard it'll take a beatin!
I personally have a 700R, I put TCI's Streetfighter kit in it and I have no trouble with it. If I had to guess with calculations, I think I'm giving it about 450+ horse off the motor, since my 385horse was RWHP. The 200's wouldn't even take 300hp I've heard.
Just some useless info, I don't know if my sources are correct or not, but they seem to be the general consensis around the boards
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
Guys run beefed up 2004R's all the time behind nine and ten second Grand Nationals. They can definitly handle the horsepower, its just a matter of building it right. I thik Art Carr makes a pretty stout 2004R. you could check out Jack Cotton's site too.
I used to offer 2004R's, the problem is getting Gran National, or Monte Carlo transmission cores (hard to get & getting more costly by the day). The other cores have to many valve body & governor problems. Yes, it can offer a little more when there is high horsepower, but as long you are under 650 realistic horsepower, then a change to the 2004R will be costly, and offer little to almost no advantage. If I had a line on good GN & MC cores and at a good price, I might reconsider doing them. Right now the 700R4's & 4L60E's are working out quite well. I don't need any more headaches.
Thanks for the reply Pro Built, This was exactly the info I was looking for and have been getting tired of the "my buddy's friend's brother who knew a guy that had one said they suck/were great" response. I had one built locally for use behind a mild Caddy 500 and my only clue that the cases were significantly different was that the shop (told me they) gave me back a Monte trans even though I gave them a diesel trans as a core. I knew it wasn't a complete lemon of a trans (I noticed the same thing Ian_F pointed out), I was just curious if one was much better than the other, it looks like neither has a clear advantage in terms of strength if built properly.
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
gixxer92
May 18, 2017 11:20 AM
