Tranny Guts
Old Jul 1, 2003 | 05:41 PM
miked's Avatar
Tranny Guts
I have a question. I know the V6 and V8 trannys (700R4) have different bellhousings and are not interchangable. I have a V8 700R4 that is in need of a rebuild. I also have a pretty freshly rebuilt 700r4 from my V6 firebird. Does anyone know if the inside parts of the V6 and V8 trannys are the same (valve body, clutch assemblies, etc...)? I just had the wild idea that instead of rebuilding the V8 tranny I could just basically use the casing and swap the V6 components into it. Is that possible?
Thanks for any replies.
Old Jul 1, 2003 | 07:31 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
I'm not sure it about it, but I think you can do that. If I remember right its only the bellhousing that was diffrent.
Old Jul 1, 2003 | 07:44 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The input shaft is different to mate with the smaller torque converter. Also remember that the V6's usually had less clutches in some of the clutch assemblies.
Old Jul 2, 2003 | 08:49 AM
miked's Avatar
In that case I might as well just do the rebuild. Thanks for the replies
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
