Let's play "How long till it blows"
Old Jul 3, 2003 | 01:05 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
I've got a 700r4 that is sitting behind my 130k mile 305 TBI. The engine is in bad shape and well is out the door.
In comes engine #2. A super ram breathing, fully forged, LT4 hot cammed, beast of a 355...
How long with a routine servicing to the tranny do you think it will last? Before I have to build something more stout. I need to basically save up for the rear and the rest of the drivetrain...
James
Old Jul 3, 2003 | 02:17 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
bye-bye tranny. I'd give it less than 500 miles. 1000 if you're really easy on it.
Old Jul 3, 2003 | 02:30 PM
Ian_F's Avatar
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
Yup, that trans is toast!
Old Jul 3, 2003 | 02:39 PM
Guest
Guest
Posts: n/a
just drop shift it once and see what happens LoL
Old Jul 3, 2003 | 02:45 PM
Engine: 355
What would it need to keep it alive? I have seen older 700R4's take the abuse of a ZZ4, granted my engine is a ZZ4 on steroids I am putting in an LS1 driveshaft and just feeling a little stuck as to what I will be able to do.
James
Old Jul 4, 2003 | 05:26 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Well **** - If the transmission is in decent shape currently, I would put a shift kit in it, to firm up line pressure so you wear the clutch packs less. New bands and Packs wouldn't hurt, and some really good ATF - Amsoil/redline/royal purple whatever you choose. A poly urethane mount & secondary tranny cooler from an autozone would help a lot as well. With all this, I think you'll last out the year.
shift kit - 25.00
bands & packs - 150.00 (EST)
atf - 40.00
poly mount - 25.00
cooler - 50.00
290.00 plus tax then the labor... is it worth it?
Old Jul 4, 2003 | 09:53 AM
Guest
Guest
Posts: n/a
shift kit - 25.00
atf - 40.00
poly mount - 25.00
cooler - 50.00
that all a VERY good idea other then the shift kit price. that sound liek the price for a POS B&M shift kit. get the Transgo kit you get alot more in the kit and it will help save your trans. also lets you shift harder and faster then a B&M kit. i have kick the *** out of a 91 GTA (350 tpi) with my 91 firebird with a 305 cuz i was able to shift faster then his stock 700r-4 (i did have alot more mods but he was a head of me till i shifted into 2nd and BOOM i was gone.
there are two things that kill a trans.
heat and pressure.. get the trans coolr for the heat and the transGo shift kit for the pressure. if you do them other things alng with the AFT and bands like D Stroy H8 said it sould last more then a year. Also get a .500 boost vavle
Old Jul 4, 2003 | 01:11 PM
Engine: 355
Well, I was thinking of either buying my buddies built tranny or just buying the rebuild kit from pro-built and than trying to get it all put together... I really didn't want to spend more than a $1k on the rebuild if I could get away with it
James
Stroopwafel
Sep 11, 2015 06:38 AM
FormulasOnly
Sep 10, 2015 09:07 PM
ronchic
Mid-Atlantic Region
Sep 10, 2015 02:32 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
