Tranny guage question
Old Jul 5, 2003 | 11:14 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Okay i just got an Autometer Ultra Lite Trans temp gauge and in the instructions they said u have to drill a hole in the tranny pan. is there any other place to mount this or will mounting it on the pan be the best place to do so?
Old Jul 19, 2003 | 11:45 PM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
You may get the most accurate measurement there in the pan, however, I have thought of mounting the sender in the tranny coolant lines. Now if you have a manual transmission then the pan is about the only option. I want to mount my sender in the tranny coolant lines but I don't know what size the fittings are and such to do it properly and get the right parts.
Old Jul 20, 2003 | 03:42 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
There is a plug in the side of the transmission that is the same size and the fitting that comes with the temp gauge. My buddy put his there and it seems to work pretty good.
Old Jul 20, 2003 | 11:22 AM
JoshDT91's Avatar
Engine: 2.8L V6
I was looking at that in my manual. It says that the fittings are 1/8" and 1/4". I should try that.
Old Jul 20, 2003 | 05:40 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
are those fittings just for manual trannys or for both?
Old Jul 20, 2003 | 06:33 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I know it is there on the 700R4 and the 4L60E. I'm not sure about a manual.
Old Jul 20, 2003 | 06:40 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
any for a th350 lol i think ill take a look next time im under there.
Old Jul 20, 2003 | 06:44 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
It is on the drivers side IIRC on the 700R4.
Old Jul 20, 2003 | 07:37 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
okay kool, now ive been here for a good 2 yrs and what does IIRC mean?
Old Jul 20, 2003 | 07:49 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
"If I Recall Correctly"
Old Jul 20, 2003 | 07:50 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
or "If I Remember Correctly"
Old Jul 20, 2003 | 07:58 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
ah okay now i know, lol ive tryed figureing it out bu no luck lol
Old Jul 23, 2003 | 05:54 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
okay hopefully tomarrow or friday ill be installin the sending unit in the tranny just for now. but will using the holes (pressure holes) on the side give me a good eading and not just reading temp from like the tranny case? or does the tranny fluid go up in those areas?
spaigo
Aug 21, 2015 07:46 PM
355sbcTPI
Aug 19, 2015 04:38 PM
redmaroz
Aug 16, 2015 11:40 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
