Trans-go on a high milage tranny
Old Jul 6, 2003 | 05:22 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I have a stock 700r4 with 82k. As of now, it shifts fine but they are slow and severely delayed when manual shifting. Will it be ok to install a transgo shift kit or just wait to get a new built tranny and just swap it? I can't really have any down time as it is my daily.
Old Jul 6, 2003 | 06:06 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The TransGo will help prolong the life of the tranny. I also reccomend the larger Main Boost and Reverse Boost valve, especially if you do alot of manual shifting.
Old Jul 6, 2003 | 06:10 PM
Pro Built Automatics's Avatar
If the fluid still looks ok?, and there is no or very little slip, then going to the Trans-Go Performance Shift kit with accumulation, Corvette servo, and boost valves can improve your situation. Or you could get a transmission built (with torque converter) and keep driving this for now, just take it easy if you want it to last. I would try the shift kit if everything seems to be ok.
Old Jul 7, 2003 | 02:17 AM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
Pro Built Automatics:
I was wondering the same thing about my 700R4. I do notice a little bit of slipping but its not too bad. Other than the minor slipping and a little bit of a delay in shifting its in good condition. It has almost 100k miles on it now. I also do a lot of manual shifting. So if i put a Transgo shiftkit in and corvette servos and boost valves would this help or would it need a rebuild? I dont have the money right now to buy a new one or rebuild this one.
Old Jul 7, 2003 | 02:42 AM
As stated above, it couldn't hurt.
Old Jul 7, 2003 | 07:52 AM
The fluid still looks good. I don't think it is slipping, you can feel it stop pulling upon shift and once completed you can definately feel it come back, but I figured that was just a slow, soft shift.
92firebirdguy
Sep 1, 2016 07:53 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
PestilenceIV
Sep 22, 2015 07:39 PM
Stryker412
Sep 7, 2015 09:11 AM
IROCZ1989
Sep 4, 2015 11:54 AM
