Which Converter to choose
Old Jul 6, 2003 | 05:54 PM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
Right now i'm looking at getting either the TCI Streetfighter converter or the B&M 3000 Holeshot converter. Would like to here some people's opinions on these converters. Or if there is any other converters out there around 3000 stall for relitivily cheap.
Old Jul 6, 2003 | 06:15 PM
90formula5.7's Avatar
re
try midwest convertors, i have one of their 91/2 " 3200 stall convertors. i have had no problems yet!!
Old Jul 6, 2003 | 06:18 PM
Pro Built Automatics's Avatar
First, "stay away" from B&M, their comeback/failure rate is very high, TCI is a "little" better. Second, if you want a stall that is over 2,200 rpm, I would advise against using a 12" stock diameter torque converter. Anything over 2,200 rpm starts to drop the torque multiplication, create more heat, are slippery feeling, etc. You will have to spend some money if you want to do this right.
Old Jul 6, 2003 | 06:22 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Re: re
I have a 2800 stall convertor from Midwest and it is working great. I agree with Pro-built, stay away from B&M.
Old Jul 7, 2003 | 07:45 PM
z86roc28's Avatar
Does midwest have a website? I have a dayco 2300-2500 rpm stall and havent had any problems, I think it was about $260, but i was thinking about a 2800-3000 rpm stall to get a quicker time...eh?
Old Jul 12, 2003 | 09:34 AM
daxfas26's Avatar
Car: cobalt ss/sc, 91 z28, 92 z28
Engine: 385 stroker
Axle/Gears: stock 10 bolt 3.73
pro built im not sure on what u r saying i got the breakaway tci converter for my setup i was told by jegs and summit that it was a 3000 stall lockup converter aint that right? and about it being 12 inches i think it is about that 12 inches or it could be 11 not sure can i get some info on that please thanks!
Old Jul 12, 2003 | 05:24 PM
The "cheap" way to get a stall (2,200 rpm & higher) is to use the 12", and lockup only. They get slippery, produce more heat, are inefficent, etc. An 11" would be a little better, but 2,400 - 2,500 rpm would be maximum if you want good driveability. There is no good way around this. 10" or 9.5" is the way to go if you want to do this right.
Old Jul 13, 2003 | 07:31 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
www.raceconverters.com
Old Jul 13, 2003 | 09:55 PM
z86roc28's Avatar
I am gonna be running about 375-450hp w/3.73 gears. Whats the difference between a lockup converter and non lockup converter that i see on the website?
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
Vincent135
Sep 28, 2015 10:50 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
