Drive Shaft
Old Jul 15, 2003 | 10:31 AM
D M N's Avatar
Car: Right now 93 Lumina
Engine: 3.4 DOHC
Transmission: 4T60-E
Drive Shaft
ok i had this weird vibration in my car and i kind of learned to live with it but not its annoying as hell i figured out from reading a couple of forums that its probably the steel drive shaft so i need to replace it with a aluminum but they are way to expensive is there some way i can get it cheaper like getting a aluminum drive shaft that came stock on a car and cut it to fit or is a corvette drive shaft the same size of a camaro i dont know can someone help me?
Old Jul 15, 2003 | 11:00 AM
ede's Avatar
ede
how do you figure buying an aluminum DS from a car that doesn't fit a f body and having it cut/lengthened will be more cost effective than buying one to fit?
Old Jul 15, 2003 | 11:01 AM
D M N's Avatar
Engine: 3.4 DOHC
because i would cut it is it really that hard??
Old Jul 15, 2003 | 11:08 AM
82camaro's Avatar
Car: 82 camaro SC
Well, I think you may have overlooked that 83 and up Camaro/Firebird aluminum driveshafts will fit. No sense getting a vette driveshaft and reworking it. Yes you can cut and weld it yourself(if you have the equipment to weld aluminum), but it has to be straight and will need to be balanced. Or, you could also have the stock steel one balanced.
Old Jul 15, 2003 | 01:04 PM
ede's Avatar
ede
drive shafts aren't hard to shorten or lengthen, i've done around a 100. all you need is a lathe big enough and a welder. you'd still be time and money ahead to buy a DS for a f body, 3rd or 4th gen.
Old Jul 15, 2003 | 01:29 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
How much are you really going to save by cutting an aluminium DS? You can get one that fits for $150.
Old Jul 15, 2003 | 02:05 PM
ede's Avatar
ede
around here it cost 100 dollars to have one shortened
Old Jul 15, 2003 | 02:47 PM
D M N's Avatar
Engine: 3.4 DOHC
83 and up?? i have a 88 and i'm pretty sure 4th gens have steel drive shafts too
Old Jul 15, 2003 | 02:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
At least some 4th gens have aluminum ones; LS1 cars for sure, maybe some of the LT1 ones too. They are a direct bolt-in to a 3rd gen with a 700 or a T-5.
Old Jul 15, 2003 | 03:31 PM
D M N's Avatar
Engine: 3.4 DOHC
huh??
Old Jul 15, 2003 | 04:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
He said, "They are a direct bolt-in to a 3rd gen with a 700 or a T-5."
Old Jul 15, 2003 | 04:21 PM
D M N's Avatar
Engine: 3.4 DOHC
so if i go and get a drive shaft from lets say a 98 v8 camaro with a T5 trans it will fit my camaro with a T5 trans
Old Jul 15, 2003 | 06:29 PM
llvll4l2c91350's Avatar
i just ditched my steel DS for an aluminum one that i got off ebay. came off a 98 SS camaro. fits perfectly and cost me $140 with shipping.
Old Jul 15, 2003 | 06:35 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Not all LS1 4th gens had aluminum driveshafts. The ones with 2.73's and automatics had steel driveshafts.
Old Jul 15, 2003 | 06:59 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
A 98 V8 will have a T56 trans, but yes, ANY D/S from a camaro or firebird, 84-2002 ,any trans, will fit a 84-2002 camaro or firebird, any trans
also, the driveshaft will fit / work in 82/83 cars if the car has a T5 or 700R4 (not a T-10 or 200)
Old Jul 15, 2003 | 07:16 PM
D M N's Avatar
Engine: 3.4 DOHC
dam cool thanks man
Old Jul 15, 2003 | 07:20 PM
icebird_1981's Avatar
r u sure its the hole drive shaft and not just the u joints. i had a similer problem before with my bird.
Old Jul 15, 2003 | 07:22 PM
D M N's Avatar
Engine: 3.4 DOHC
someone has been telling me that a defect in the design of fbody cars is the steel driveshaft vibrating alot
Old Jul 16, 2003 | 05:23 AM
ede's Avatar
ede
another common defect among cars amd trucks equiped with u joints is the u joint going bad and causeing noise and vibrations, maybe you ought to get under your car and take a look, do a little trouble shooting before you go buying parts you may or may not need.
Old Jul 16, 2003 | 08:18 AM
82camaro's Avatar
Car: 82 camaro SC
I agree, my stock steel shaft is vibration free, including running it up to 5000rpm in OD(the driveshaft is spinning pretty fast).
Old Jul 16, 2003 | 08:20 AM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
I'm sorry for this, but I can't understand what half of you are saying. Please use periods.
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
Ozz1967
Aug 16, 2015 10:23 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
