bad vibration in 5th gear
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
very noticeable at highway speed in the sense that it shakes the car like the world is coming to an end. also noticeable at lower speeds but only if paying attention to it.......... i have isolated it to the trans, because if i drop to 4th gear it seems to go away.
i don't powershift the car, i don't do extreme speed runs and that stuff, more or less just drive i have made a half dozen or so passes down the strip, but never get any traction.
what may be the problem here?
btw the following items were replaced in efforts to kill the bad vibes,
tried 2 diff driveshafts.
replaced u-joints in shaft that will remain in the car
new trans mount
balanced tires
i need to know what to look for if i tear the trans apart, a friend and i have been inside a t5 before so thats not a problem at all
thanks in advance
new trans mount
balanced tires
thanks in advance
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
vibe
You might try to see if the vibe is there in neutral and reving the engine to the rpm where the vibe occurs.
Do you have AC? I took off my AC belt and the vibe went away.
Scott
Scott
ambainb
Apr 25, 2016 09:21 PM
