Trans Problems, Wont Come Out Of 1st Gear
Old Jul 16, 2003 | 10:12 AM
reilly8282's Avatar
Car: 1988 IROC
Engine: l98 350 tpi
this is a daily driver so as you can tell im very disturbed at this happening at all the wrong times. I was pulling into my garage to stop and put the car in park from 1st gear (700r4) i go to put it in OD so i can put it in park and the minute i try to slide the lever up i hear this cracking noise and it wont shift out of gear at all even if i try to force it. i took the shifter plate off and there is a plastic peice broke and a rubber bushing out of place and i cannot get it out of first, cant even start the car of take the key out!!! im gettin pissed off and need help the shifter lever will slide freely up and down but wont disengage....
Old Jul 16, 2003 | 01:14 PM
reilly8282's Avatar
Car: 1988 IROC
Engine: l98 350 tpi
i guess theres this little plastic piece that holds the cable straight/stiff, so you can shift gears with the shifter and if has broken im hoping thats all the problem is, any input would be helpful!
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
hokis
Aug 9, 2015 03:57 PM
