after transmission install I NEED HELP!
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
i dropped the tranny to put in a new front seal because it blew out. everything's fine, TC is unmarked/cracked no sign of wear anywhere in the front. pop the seal in put the tranny back in no biggie. Hook up all the wires/cables and the shift bracket. everything looks fine. Start her up once im done and go to shift from park into reverse. its in neutral? i shift back to park and its in reverse? ok...then i shift to OD to move forward and its real loose and if u poke the shifter it comes out of that gear...whats up with the shifter? is the bracket underneath screwed up? or how do i adjust it?
Car: 84 Z28
Engine: 355c.i.
Transmission: Turbo 350, w/shift kit
disconnect the cable from underneath of the car. Put the shifter in park, then put the tranny in park with your hand on the bracket, then just adjust the bolts so you can move to cable down and put it on the bracket while its in park and it should be ok.
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
i really need help with this, i have to get the car running by tomorrow nite...can someone explain this to me? because the shifter is loose now(i didnt disconnect anything at the shifter, only the tranny during removing and replacing it) and the shifts are messed up (not shifting into the right gear when you move the shifter.)
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
When you dropped the tranny, there was probably enough tension on the cable to shift it out of park. I can't remember which way the lever goes. Just put the car in park and get under the car and push the lever. Your only off by one gear. If the lever goes more than one click, you went the wrong way.
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The nut that attaches the cable to the shifter lever on the trans is adjustable... You simply need to turn the shifter lever on the trans all the way clockwise (this will be park), then put your shifter in park, then reattach the cable to the trans shift lever..
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
ok i got it in park, but i lost the nut somehow to the cable that attaches to the bracket. What size is this nut? if anyone can check and post it, i'd be more than grateful..thats the only thing i really need now
ambainb
Apr 25, 2016 09:21 PM
