all you manual people please come in i need some pictures please.
Old Jul 26, 2003 | 10:29 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Okay now i have chosen to go with the t56 i need some pictures of what the i think its called this the
HYDRAULIC MASTER/SLAVE CYLINDER goes on the car because everybody here i know has an auto.
thanks for any pictures also if you could how much farther did you have to cut back to put the shifter on the trans.
Old Jul 27, 2003 | 01:15 AM
Z_Ghost's Avatar
It to late at night to get a pic of it on the car, but maybe this will help.
I can take one of it on the car Sunday for you if no one else does.
Attached Thumbnails all you manual people please come in i need some pictures please.-.jpg
Old Jul 27, 2003 | 07:59 PM
Z_Ghost's Avatar
Here is on of the slave cylinder on the car.
Attached Thumbnails all you manual people please come in i need some pictures please.-mvc-010f.jpg
Old Jul 28, 2003 | 07:03 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Keep in mind...Z_Ghost has an aftermarket T-56. The GM unit has the slave mounted from the rear instead of the front. I'm planning on changing the oil in my RS this week...when I do I'll get some pics of how the slave mounts while the car is up on the lift.
Old Jul 29, 2003 | 04:17 AM
Z_Ghost's Avatar
That's the stock T-5 bell housing.
Old Jul 29, 2003 | 06:45 AM
TheGreatJ's Avatar
The aftermarket T-56 uses the stock T-5 bellhousing doesn't it? So the clutch setup should be identical except for the input shaft size/spline count which you can't see anyway......at least that's what I thought.
Old Jul 29, 2003 | 07:06 AM
Momar's Avatar
The aftermarket uses the t5 bell housing an clutch. I would imagine that the input shaft is the made to match that of a t5 also since it uses the t5 clutch.
Ben
Old Jul 30, 2003 | 04:37 AM
Z_Ghost's Avatar
With the aftermarket (retrofit) T-56 you use the same clutch as the T5.
The stock T-5 bellhousing and clutch setup is used, the retrofit T-56 comes with an adapter plate that bolts to the bellhousing and then the trans bolts to that.
In the pic you can see the plate bolted to the bellhousing, the trans is going on this weekend.
Attached Thumbnails all you manual people please come in i need some pictures please.-mvc-007f.jpg
Old Jul 30, 2003 | 05:04 PM
tbfirebird's Avatar
Engine: ??????????
i have an auto matic so i thought that all i had to do was buy all the little parts like the crossmember and slave cyclinder and the t56 from any year 94to97 would bolt right up to the 305 tbi with 1 rear main seal.
Old Jul 30, 2003 | 06:30 PM
TheGreatJ's Avatar
The GM T-56 will bolt right up to the 305. You have to use the T-56 bellhousing, clutch, flywheel, clutch hydros, and shifter and a conversion crossmember.
You only use T-5 parts for an aftermarket (a.k.a. retrofit) T-56.
Vintageracer
Jan 10, 2020 05:33 PM
deracer
Apr 11, 2016 12:04 AM
chubsworth
Aug 26, 2015 02:34 AM
g.l.mos
Aug 22, 2015 12:02 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
