Skip Reverse?
Old Jul 28, 2003 | 03:56 PM
Kao91's Avatar
Skip Reverse?
Hi,
I have a 91' automatic RS camaro. Today, out of the blue, the car won't go to reverse from park -- it skips the gear. I can get it into reverse, however, by moving it into drive and then pushing it back up into R.
Other symptoms include having to go down to D1 (it won't go directly into overdrive) to get the car to engage. Also, when I try to put it in park, the car seems like it's in netrual. Only after putting a bit more pressure and waiting awhile will the car go into P.
I checked the tranny fluid level and it looks fine. The car also shifted fine when Drive was engaged.
Any help would be appreciated.
Thanks,
Brian
Old Jul 28, 2003 | 07:11 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Sounds like an issue with the cable/linkage to me, but I'm not exactly a tranny specialist.
Old Jul 28, 2003 | 07:14 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
i agree
mine wouldnt get into drive, or any gears lower then neutral, found out the cable was frayed and split open
Old Jul 29, 2003 | 07:40 AM
Kao91's Avatar
Yep, you are right.
Apparently one of the bolts holding the linkage cable to the car had completly come out. I went to Home Depot and replaced it.
Final Cost of Repair = .32 cents
I wonder what they would have charged me had I brought it into a shop....
F-body driver
Mar 6, 2023 11:44 AM
Veaceonee
Sep 29, 2016 08:15 PM
nova983
European Region
Nov 2, 2015 12:15 PM
Zane Story
Oct 8, 2015 12:40 PM
84redta
Sep 19, 2015 09:58 AM
