HELP with shift kit...
Old Aug 6, 2003 | 10:42 AM
19WS6T/A91's Avatar
i brought my car to the shop yesterday to have my vigilante stall and trans go shift kit installed, when i return to pick it up it has no reverse. what would cause this?
Old Aug 17, 2003 | 11:19 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I put my transgo kit in yesterday and I don't have reverse, did you ever figure out what was wrong?
Jason
Old Aug 18, 2003 | 08:08 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
No reverse is caused by the pressure regulator valve being installed or assembled incrorectly. Sorry guys the pan has to come off one more time. Glad when I had the 7R4 I opted for the drain plug.
The valve most likely isnt clipped in the correct upper grove, this is the one in the tranny case on oposite side of the dipstick tube. Anyway always a good idea to pull the whole thing down and recheck anyway, I persoanlly put it togather wrong and had reverse untill the pressure poped the clip out 3 days later.
Old Aug 18, 2003 | 12:25 PM
LilJayV10's Avatar
Engine: 406 Roller
I know for a fact that I put the snap ring in the first groove.
I will pull the pan tonight and fix it. I want to drive it now. I started it for the first time last night and that cam sounds awesome.
Thanks for the help, hopefully this is the only problem I will have.
Jason
Old Aug 22, 2003 | 01:25 AM
19WS6T/A91's Avatar
also while you are there, check that valve, mine had a slight burr on it and would not slide freely, that was my whole problem
Old Aug 22, 2003 | 06:36 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
haha, that's funny, mine had the same problem a few days ago too when being put in.
guy at trans-go said the same thing, if you aren't in the upper groove it won't reverse or shift right all due to that valve.
he was right on the nose, worked.
i'm not used to the jerking when the car up/downshifts, but it's fun in the open road!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
