T5 Grindes when shifting into 5th
Old Aug 7, 2003 | 02:13 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
T5 Grindes when shifting into 5th. 1-4 are completely fine, but when I try to shift into 5th it sounds like the gears are grinding, then it goes into gear. Does anyone know what causes this? My guess is the tranny is prob. in need of a rebuild soon.
Old Aug 7, 2003 | 11:18 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
inside the case itself is the main shaft which the gears are on...the cluster shaft is under that which the power is diverted through the output...
the 4th gear and 5th gear "sandwhich" the case..in other words the 4th gear is inside the case and the 5th is outside...
the problem..on how your describing it sounds like your 5th synchro assembly is worn..pretty easy fix...but of you want to rebuild it then i suggest www.hanlonmotorsports.com
you didnt say what year your car is so the price on the rebuild kit will be determined by which t-5 design you have....
up to 87 is the first and weaker design..or the NWC (non world class)...87 and up is the WC...
169 for the NWC kit and 199 for the WC....
also get the video!!..watch it twice before you do it and during it
i just did it to mine about amonth ago...very very easy..really starit forward...
Old Aug 8, 2003 | 09:26 AM
TA5LiterHO's Avatar
The tranny is a 92 World Class. I believe I have purchased parts from them before. I would probably rebuild it myself. I rebuilt my 700r4 when I had it. I just recently did a manual conversion and the tranny I used has about 70,000 miles on it so I figured it may be a syncro. Does hanlon have just individual parts to? Thanks for your help.
Old Aug 8, 2003 | 09:30 AM
TA5LiterHO's Avatar
Thanks again hopefully I will find time to fix it soon.
Old Aug 8, 2003 | 01:20 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
any special tools needed for the t5 rebuild, 2nd and 3rd are on theyre way out for me, i will be rebuilding as soon as i get a job...for now no racing
Old Aug 8, 2003 | 04:25 PM
TA5LiterHO's Avatar
Gear puller.
Old Aug 9, 2003 | 07:39 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
unless you have a press then a gear puller isnt nessesary
the rear cluster bearing has to be pressed on...both maninshaft and the input...the 5th driven gear has to be pressed off...
yes hanlon sells parts alone...pretty competitivly priced to
the only "tools" you need are a 3/16 pin punch, caliper and snap ring pliers...preferbly inner and outer...
Old Aug 10, 2003 | 05:10 AM
Odyssey's Avatar
Snap ring pliers and retaining ring pliers!!!!!!! You'll have a hell of a time getting the retaing rings off with the snap ring pliers. LOL
Old Aug 10, 2003 | 07:10 AM
TA5LiterHO's Avatar
I'm gonna call them on monday. I got two Spare WC Borgs out of v6 camaros if anyone needs one. Each has about 50,000 on it. Just needs a v8 mainshaft. Same gearing and internal parts just fewer splines.
Old Aug 10, 2003 | 07:13 AM
TA5LiterHO's Avatar
I've also got some other misc parts if anyones interested.
Old Aug 10, 2003 | 09:02 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The mainshaft is the same from a 6-cyl to a V8.
The things that are different are the clutch gear and the countergear. The clutch gear has different spines; and the 2 gears have a different ratio where the clutch gear drives the countergear.
Old Aug 10, 2003 | 09:49 PM
TA5LiterHO's Avatar
Thats what I was trying to say. Didnt know the exact term. Less splines on v6. hehe
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
DARKmj16
Sep 9, 2015 04:07 PM
