Trans fluid leaking from the gauge fitting any other better.
Old Aug 15, 2003 | 05:19 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Okay ive bought a autometer trans fluid temp gauge.I have a trans fluid cooler with a fan and the it goes back in to the normal cooler in the radiator and then back to trans i have a t fitting i bought at ace and with some metal extensions comeing from the t fitting and then about 2inches of rubber hose's on each side. then ends clamped on there(2 clamps on each side) then the sender in the t fitting.But i have to add tranny fluid like everyday and to day i noticed that its leaking from the where the rubber hose goes over the metal extension.And the threads have tranny fluid comeing from the t fitting.But i wraped it like twice with that white tape crap.Anyways i would like to know any other ways to get that reading and i was thinking about running steel bradied lines from the tranny can i get to the cooler lines where there on the tranny do i have to take the tranny off to get to the lines to take them off.Also i wanted to know what might be leaking if its no all just the t fitting because i changed my tranny fluid when i put a new tranny mount on the so it was really easy to put the gasket on the tranny pan straightso i know that dosent leak but i saw fluid on the crossmember alot and then one time when i was driving i saw just a little smoke just hardley any.Coming from the passanger side but it could of been that little pin hole thats in my cat.
SORRY for the long post.
Jeremys87
Jul 14, 2022 09:08 PM
maroe624
Apr 16, 2017 08:29 AM
Reddeath210
Oct 6, 2015 08:20 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
