t-56 install help please
Old Aug 29, 2003 | 09:19 PM
IrocindatZ's Avatar
Car: 1989 IROC-Z
Engine: 350 TPI w. Bolt_ons
Axle/Gears: Dana 44 3.73
ok guys i am doing my swap, started tonight and things have all been going real smoothly. I have run into one problem and that is where and how to mount the clutch master cylinder onto the firewall. my car didn't come with either holes or dimples for reference. can anyone get a somewhat decent measurement and possibly a little info on how to go about doing this?
James
Old Aug 29, 2003 | 10:12 PM
IrocindatZ's Avatar
Car: 1989 IROC-Z
is this on of the holes that the cluth master cylinder mounts into???
http://www.angelfire.com/mech/my96mustang/camarot56
Old Aug 30, 2003 | 09:09 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
pull back your carpet inside the car by the pedals. look at the sound insulation. you should get a beter Idea that way.
Old Aug 30, 2003 | 06:11 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Mount your pedals. They should have the 2 outer holes for where the u bolt goes lined up. Drill them holes.
Then in the middle of them, drill a 2 1/2" hole for the master cylender. Thats how we did it on the 2 I've helped do so far.
Kat
Old Aug 30, 2003 | 10:08 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I used the 4th gen pedal assembly as a template, because I found it easier to drill from the engine bay than from inside the car. You can figure out where the holes for the master cyl should go in respect to the holes for the brake booster. I was really **** and used a ruler and a compass. It lined up perfectly. Then do as Kat said and put the big hole right in the middle.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
gixxer92
Sep 1, 2015 04:32 PM
Hello, Michael
Aug 20, 2015 03:19 PM
cRoe4
Aug 7, 2015 08:46 PM
