700r4 to 400 turbo
Old Sep 7, 2003 | 07:00 PM
1badze's Avatar
700r4 to 400 turbo
Has anyone out there done a swap from a 700r4 to a 400 turbo, if so, did you run into any problems with the floor boards? what did you have to do with the crossmember, torque arm, and driveshaft?
Old Sep 7, 2003 | 07:18 PM
idrag2's Avatar
I can tell you that B&M makes a bracket for the toqure arm, bolts to the tail housing, and it costs about 90.00
Old Sep 7, 2003 | 07:35 PM
EvilCartman's Avatar
Car: '82 Z28
The TH400 will fit under the car no problem. Just to make life easier I went with the Spohn crossmember and torque arm for my swap. The driveshaft on mine was the right length (car came with a 200c trans.), just needed to put a TH400 slip yoke on it and have it balanced. Probably the best way to get the right driveshaft length is to get the transmission in the car and measure.
Hotrodboba400
Dec 10, 2019 07:07 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Vojtush31
Oct 11, 2015 01:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
